Winter tinkering or maintenance ?
chrisg
Dear All
Now the nights are well and truly drawing in (winter is coming....) just a quick reminder/ unsubtle plug for the pin spanners and 24/27mm spanners available for belts/waterpump changes:
https://plus4e.com/shop/#!/Tools/c/16407026/offset=0&sort=normal - or from me via PM.
There is also (although not advertised) a drift specifically designed for installing & seating the front crankshaft oil seal.
Happy tinkering
Chris
Winter tinkering for me is likely to be (after more insurance paint, hopefully) a wheel bearing, torque tube bearing, brake bleed , rota and dizzy cap along with a brake bleed and clutch and a lightened flywheel.
Hi Christopher
I dug out the 944 after a few months of inactivity - got a dead drivers window so need to replace the regulator i think. Other than that, it's all working :)
Can Nick make some plugs for the bellhousing that stop you dropping anything in when setting up reference sensors? [:(]
