Wiper / indicator stalk removal - 944 S2
- Thread starter rowey200
pauljmcnulty
924nutter
Yes, it's an easy job. Take all the trim off (it's a fiddly job but not at all hard) and look at the way that the column switches are held onto the column - there is a band that goes around the column with a pinch bolt at the bottom. Slacken that pinch bolt off and slide the switch assembly off the column, unplugging the wires from the back as you go. Yes, you do need to put the new assembly the same distance down the column as the old one was but it can (just about) be adjusted in situ.
