My wipers do a little skip every so often when wiping, a bit like its met an obstruction and then it moves past it. They also judder after using the wipers for a while. I have changed 2 sets of blades and the springing on the arms appears correct. I even oiled the hinge on the arm as sometimes when it rusts the arms don't apply the right pressure on the screen. I applied Molykote to all the lever hinges under the scuttle but it has made no difference. Could it be the motor playing up? If it is, does anyone know where I can get it cheaper under the Bosch part number 0 390 241 351 as most places are selling it for £180-200.
Wiper Motor
- Thread starter minny
Does the skip happen when you operate the washers? If so, they all do that.
It is different from the skip when the washers operate. Sometimes it wipes away happily then it does this jump of 2 inches either up or down the screen in the direction the wiper. after this happens, the wipers would start to judder. Actually judder is probably the wrong term - the sweep is jerky.
