wipers
- Thread starter Guest
Edit:
Everyone beat me to it [8D]
ORIGINAL: boxsterboy
Although, mine still make the most horrid screaching noise and miss a part of the screen infront of the passenger..
Any advice!
Mine don't screach, but the passenger side doesn't wipe as well as the drivers side either.[:'(]
My problem is the that the driver's blade doesn't sit perfectly on the screen, the end of the blade that wipes the middle of the screen always leaves a trail behind. It's a minor problem but it does crack me up. Anyone else noticed this?
JCB..
Non-member
May I recommend this site to a few people? [&:]
http://dictionary.cambridge.org/
Screech is contained within, screach has yet to make it![
I thought things were improving since Helen sold her Boxster!
JCB..
Non-member
I'll let you off just this once! [8D]ORIGINAL: Mark Bennett
I wasn't going to point that out - so copied the original spelling []
The blade should sit at 90 degrees to the glass, poor handling of the arm when cleaning the rubber wiper bends the steel slightly, judder can also occur when the blade itself is very old and the joints become loose.
If the arm is slightly bent the wiper wips well in one direction and judders in the other, if the wiper blade is worn out it will judder in both directions.
see dead easy
Glyn
Wonder if you (or anyone else) can help me? Before I try out the wipers advertised by Carparts as having won out against several other makes in an Auto Express test, is the only difference you can see in the ones you have just bought from Porsche re. the spoiler thingy? I.e. as far as you can tell, is each the same length and shape? (the Carparts ones have no spoiler and appear identical).
Cheers,
Mike.
just gone to replace my wipers today,, the ones i have on are both 22inch blades,, but the recommened are 22 drivers and 20 passengers... the other problem i have found is the passenger one is curved... i guess this is because its 22 inch
can anybody tell me can you get curved or has previous owner bent it to fit?
Also was looking at borsch ones any ideas on good ones
http://www.porscheshop.co.uk/acatalog/porsche_boxster_service_items.html
or they are around 25 pounds for the pair from the dealer.
