peanut
Hi all hope someone can help as I now stuck.
I need someone to verify where 2x wires lead to from the underside of the fuse relay box on my 1989 S2
The wires tails that have been left have been cut very short and I have been unable to verify the connection they should make from the wiring schematics I have.
On the E connector block plugged into the underside of the Central Electric (Fuse Relay ) block there are 2x small identical black/yellow wires approx 1.0mm
I need to know if these two wires should be joined together as a LINK as I suspect they do ....or should feed into one of the many wiring looms that connect to the underside of the fuse relay box.
it should be possible to see the wires coming out of the E connector block with a torch looking up from the passenger footwell. Perhaps someone may have a spare fuse relay box and loom off the car or accessible ?
