Wonky light covers
homesea
I have a wonky headlight cover and it's been annoying me for ages, it's only a couple of mm out but it drives me mad.
So do I adjust it at the triangle bracket circled in green?
(Sorry for pinching your photo Nick).
Yep, and there is another one the other side of the light inside the front wing. You can get to it through the inspectionflap in the front of the wheel arch liner.
Do it on a day when you're in a good mood with plenty of patience [;)]
One of mine rests about a cm too high where the other rests about a cm too low, I have no idea how to adjust them though.
ORIGINAL: madrob6
Unless there is some other method, I believe sliding the mount for the operating shaft and motor fore or aft as appropriate will correct this. Of course it will also affect the "up" position so headlights may then need adjustment.
ORIGINAL: madrob6
1. Loosen all 6 bolts on both triangular plates either side of the headlamp pivot. 2.
2. Move the headlamp to where you want it to be
3. Tighten up the 6 bolts while supporting headlamp position
4. Swear profusely as one of the bolts moves the headlamp a little [:mad:]
5. Repeat above ad nauseum until it's just right [:)]
