Copperman05
I have a problem with selecting 3rd gear. It happens when changing down, from 4th or 5th into 3rd, I push the lever up and its as though something is obstructing or blocking its path, the lever will not go forward. There is no grinding or grating noise, it just wont go past the neutral position.
What I have to do is move the gear shifter into 2nd (with the clutch still in) and then into 3rd, this seems to move whatever it is out of the way allowing me to select 3rd gear. This problem only appears when the car is moving, when stationary I can select all gears and nothing blocks its way into 3rd, but when moving, changing down into 3rd is always blocked in this way.
Occasionally it happens when changing from 2nd into 3rd, but this is rare and often when the car is cold, a quick shuffle of the gears in and out of 2nd seems to free it up.
I have had RPM look at this and Ollie said it wasnt anything he had ever seen before...The gear linkage on top of the gearbox has since been replaced by a short shifter I inherited from the previous owner and the gearbox oil has just been changed by RPM. The problem persists.
Has anyone experienced anything like this before? I have read on another thread that selecting 2nd gear 'moves' some gear cogs out of the way, perhaps one of these is jamming inside the gearbox. I think we can rule out any linkage or gear stick issue as the problem would remain when stationary.
I was hoping that i wasnt going to have to buy a second hand gearbox quite so soon and a rebuild seems expensive. The box has a whine also, but this has improved since the oil was changed.
Any light on the matter would be appreciated.
Edd
Edd
