Workshop manuals
- Thread starter vitesse
pauljmcnulty
vincematthews
http://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/
This gives you an official PDF version of PET.
If your car is an old one you probably need to check with an OPC to see if the part is still available.
Unfortunately I don't think either of the two sources above mention 924s .
Phil at porsche@technigold.co.uk was a source someone mentioned to me a while back but no idea how kosher it is.
CarreraRSR
http://www.porsche.com/uk/accessoriesandservice/porscheservice/originalparts/originalpartscatalogue/
pauljmcnulty
I've heard that Haynes manuals are incredibly helpful and reliable? [][][][]
CarreraRSR
ORIGINAL: VITESSE
Thanks everyone-however it is the Workshop Manual part of PET I am after-I've got the Parts Section.
Ah, workshop manuals, they are quite elusive but can be found if you look hard enough
pauljmcnulty
Excellent. Might be worth stickying it, or adding to 924 faqs? [8|]
vitesse
Thanks for your help-I had found the manual on Rick's site-clearly one has to use the 944 2.5L version for the 924S-I have the Haynes manual which is OK for the basic stuff but has not much technical info-in fact the Haynes manual for the 924 is a much better book.
Cheers,
Colin.
