I am an avid reader of the many posts put up, but this is only the second I have ever written so I want all to understand - this is serious.
My dear "black and tan" (ok I know its sand) 2005 987 S has probably not had the best life of any Boxster, but for the 7 years I have been the owner I have tried to provide suitable care on a moderate budget. With little more than my previous 986 S I have always believed there has been a slight engine whine, that I have always believed/hoped was belt or auxiliary item related. Definitely not transmission or drivetrain. As items such as belts have been replaced and investigations have come and gone the sound has never departed or really changed. Unfortunately a week ago on the way to Brookspeed (my local support) for some other work the sound became more pronounced. After some hours of investigation they have discounted water pump, belts and tensioners by disconnecting all they could. The sound is now clearly a background whine when revving up and what now appears (with covers removed) to be a rattle as the revs fall away. It is more pronounced when warm and appears to lower central and at the front of the engine. The oil pump was suspected but according to Porsche colleagues these almost never fail and the potential "pressure spring"? which can fail was checked and found to be ok (no other debris being noticeable in the investigation).
So the question is does anyone else have a clue? Brookspeed will continue investigations and checking other sources but I wanted to call upon what I hope are some all knowing fellow members to share their experiences. Many thanks to all who do.
