Wrong slotting?
If you downshift into first from flat out in second, no electronic rev limiter will save you!
Of couse, a tiptronic won't let you! (smug look) [;)][;)]
edit: Damn! - beat me again Mark!
...and I believe the on board computer logs this, so you are likely to be refused a warranty claim too.
That's right Kish, it records the number of times it has been over-revved. I did a quick calculation of the engine speed if you engaged first gear after having hit the rev limiter in second - 12700 rpm. Not much surprise it went bang.
ORIGINAL: Richard Hamilton
I have the 997 S with what I believe is an Aisin gearbox - RR 6-speed Manual Transmission (MT) http://www.aisin.com/product/automotive/drivetrain/mt.html and it has triple synchromesh on 1st/2nd, double on 3rd/4th, single on 5th/6th and the feature that it will only go into gear when its ready. I found 1st and 2nd gear difficult, it's getting better, but if it's not stationary or close to it, then 1st isn't selectable.
