Here are some pictures as promised.
Here is the left hand side ballast box. Note two fuses next to it which are for each box.
http://i122.photobucket.com/albums/o241/neil964_photos/Xenon%20lights/BallastboxLHS.jpg'>
Here is the right hand ballast box. The wire to power it runs along the front and is tie wrapped up.
<IMG src="http://i122.photobucket.com/albums/o241/neil964_photos/Xenon%20lights/BallastboxRHS.jpg
The pair of ballast boxes. They are at that angle because the brackets that come with them are flat with holes in them (a bit like meccano) and the available fixings are two nuts that fix the top of the bumper on just under the plastic lip.
Here is the changeover box from Hi to Lo beam.. One wire goes through the gromet to the plug on the back of the headlight. The other three are to the ballast boxes and on to an earth and the positive feed.
On the left hand side of the light bowl you will see a 25mm hole which I drilled and lined with a gromet. Because of where I put the ballast boxes the lead from the light bulb (which is about 6" long and the wire from the ballast box is about 12" long) isnt long enough so you have to have to push the wires through to the wing then plug them all together (there are 3 wires and its impossible to mix them up) and push the plugged wires back into the wing. The connectors are waterproof but as its a lined wheelarch no water will get in. The original hole on the right where the headlight plug came in I first plugged in the changeover box then wrapped it in insulating tape so it cant come apart and pushed it back into the wing to create space in the light bowl.
I drilled a 25mm hole through to the wing here and lined it with a gromet. I could have used the original one next to it but it would have been too tight to get the plugs for the lights through and have the pipe in the apeture too. Plugging the lights into the ballast box is the same as on the left hand side but there is no need to plug anything into the original headlight socket so again that was wrapped in insulating tape and pushed back into the wing. Note the earth point on the left which has an extra wire on it now which comes from the wiring loom of the changeover box
Here is a picture of the kit as it comes from the manufacturers. You will also get a smaller cardboard box with the changeover box
Here is the difference in light quality between the xenons and filament lights. It is a white light and had no blue in it. You can see how yellowy the filament ones are by comparison.
Regards,
Neil Eldred
