Yet another engine ticking noise post
- Thread starter chard
What was the oil level while warm from shutdown?
Possible air trapped in the hydraulic tappets but should clear by the time the engine has warmed up for a few minutes.
The holes in the tappets can gum up in high mileage engines but it shouldn't have happened on a 987 using Mobil 1
I know it can be a worry!
But it usually clears, try again tomorrow.
Oil level should be at max with engine warm about 5 minutes after switching off, as the oil expands with running. Only top up if the oil is low when hot. Overfilling can cause oil foaming which can effect some crankcase breather systems.
No need to drain any off, just not to jump the gun when finding it's dropped below full.
Like many others I prefer to have a dipstick as well as the gauge which is handy to use but not so accurate and isn't good for assessing if you've overfilled.
I miss having a dipstick.
