I've just replaced the flexible fuel line joining the two parts of the engine bay hard fuel line, and reconnected the carburettors with two copper crush washers, one on each side of the banjo bolts
On testing the fuel system under pressure, both outer sides of the banjo belts are leaking ever so slightly (see photos) so should there only be a copper crush washer on the inside of the banjo bolt?
I have tightened the banjo bolts to reasonable hand tightness but didn't want to overtighten then for risk of stripping threads on the carburettor or similar
Any advice much appreciated and I would urge other owners to check their rubber fuel hoses on a regular basis as the joining part on my engine that was hidden behind the back of the engine was leaking like a sieve!
Many thanks
Alex
Many thanks
Alex
![10BDFF5008F64B8C904A95B0425E27AD.jpg](https://www.porscheclubgb.com/forum/legacymedia/upfiles/44010/10BDFF5008F64B8C904A95B0425E27AD.jpg)
![73DFC1114FC34AB4A13AEA68A68E61D5.jpg](https://www.porscheclubgb.com/forum/legacymedia/upfiles/44010/73DFC1114FC34AB4A13AEA68A68E61D5.jpg)
