Zenon Headlights
- Thread starter Hailstone
BartyB
If you do fit an aftermarket kit, you might get nice bright headlamps but you risk dazzling oncoming traffic, getting pulled by Plod under Construction & Use, invalidating your insurance and failing the MoT unless you swap the lamps back for the Test. And, from the ones I've seen, most Xenon kits are made in China and many are of dubious quality. Caveat emptor.
berty987
Black80XSA
The 987 headlamp is a projector beam style so has a lot better control of the headlight beam than the old reflector units in the 986 series cars, you are less likely to dazzle any ongoing traffic. I never got flashed int he 986 and never in the 987 either. Early cars don't seem to be throw errors on the computer, but newer cars will (can be overcome with resistors), although i don't know when the cut off is.
You could try Osram Nightbreaker or Philips Extreme Plus bulbs - these are halogen bulbs with a higher percentage of xenon gas in their mixture, and an optimised filament for improved light output. £20 a set.
If you do go down the xenon kit route then suggest you look at hids4u website - uk based and probably better quality and after service than a cheap Chinese kit off ebay.
And in today's fog, about 15% were driving about with no lights at all. For goodness sake people, read the highway code: headlights are mandatory in fog! Glad to see every Porsche I saw - and waved at - had their headlights on.ORIGINAL: Black80XSA
Plod isn't interested - about 15% of cars on the road only have one operational headlight...
Sorry - rant over. Isn't there something in the vehicle regs about having to have headlight washers too?
