When parked, the Macan wiper blades are neatly set down below the bonnet line to reduce drag and in an ideal location - unless you want to clean your windscreen or change a wiper blade. [
Porsche have given some thought to this problem and have provided a way of making it much easier to work on this area.
After switching off the ignition, you simply press the wiper stalk downwards briefly and this will bring the wipers to roughly halfway up the windscreen.
A little tip that may be worth remembering. [
