devans
Hi all. Car has been laid up for the past 12 months but have decided that it needs to be my daily drive again. Started it up and whilst it starts OK as soon as I put my foot on the pedal it loses power. Ticks over ok but can't get enough power to pull away without it stalling. Put a diagnostic check on it and the following came up.
P1602 factory fault code 108-power supply open circuit
P0300 factory fault code 75 misfire damaging to catalytic converter
P0302 factory fault code 64 misfire, cylinder 2, damaging to catalytic converter
P0304 factory fault code 66 misfire cylinder 4, damaging to catalytic converter
P1319 factory fault code 62 misfire emission related
P1314 factory fault code 51 misfire cylinder 2 emission related
P1316 factory fault code 53 misfire cylinder 4 emission related
Am I right in assuming that all these are related to a possible coil fault on banks 2 and 4?
i serviced the car just before I laid it up 12 months ago changing air filter, oil filter, oil change etc but have yet to change overdue plugs. Before I look at the plugs and coils do any of the codes above lead to the petrol filter or should I just go ahead and do the coils and plugs?
thanks in advance for any advise.
