kasspa
Hi All,
just washed my car, took it for a spin to dry out brakes & L/H indicator warning on dashboard flashing fast....... damn, I thought!
got home to investigate, bulb in n/s headlight unit not working.....
Out comes the European bulb kit that I put together, headlight out, bulb replaced, headlight replaced & same problem....... try the hazard lights I thought to confirm & strangely the indicators flash as they should!!
So my question is: has anyone else experienced this, why does the bulb work on hazards but not on the turn indicator, what could it be & what is the'fix'?
At least my rear indicator is working properly......
Secondly, despite replacing batteries recently in r/c's, locking/unlocking the car with them is becoming intermittent.
I know car goes to sleep after approx 5 days, unlock car manually, then press remote..... sometimes works, sometimes not.....
Open car door, put key in ignition to stop the alarm, car starts..... however central locking light/switch by PCM remains illuminated, fuel filler cap cannot be opened nor does passenger door from the outside....... has anyone any thoughts/knowledge about this? (Please Richard [
1 of my r/c's is dead again (not sure if this is draining internally) & the other, red light flashes rapidly but at the moment opens/locks the car ok.
I will replace the CR2032 batteries again (as this is cheapest option) but have read somewhere that the r/c's may be 'fried' .......
Have they reached their sell by date?
Car is 2004 C4S.
Any advice appreciated, thanks.
Merry Christmas to ALL.
Paul (Kasspa)
Car is 2004 C4S.
Paul (Kasspa)
