Good afternoon. I need your help please. I have a ‘98 986 Boxster with a flat battery. The front lid is locked and can’t access the battery to jump start it. I can get into the car but the levers are locked. I have tried removing the lever cover by the driver seat but can’t get Alan keys to turn anything. I can’t remove the inner wheel arch covers to find the infamous emergency release cable as the jack and wheel nut is in the boot. Someone has suggested attaching a charger pack to a positive terminal that can be found on the fuse board but there isn’t a terminal like those on later models. Someone else has suggested removing the fuse board by the 4 screws and the release cable should be behind that, which I can pull to release the boot lid. So I have 2 questions.
1, Is there somewhere else on the car that has a positive terminal that I can attach a charger to, to create enough power to activate the car and release the lid?
2, By removing the fuse panel, is the release cable behind there or am I just being too hopeful?
I would really appreciate your help with this.
Regards. Jon Bryan.
Regards. Jon Bryan.
