cayman_rich
Hello all,
New here but have been on here for a little while and owned my 987 Cayman 2.7 for about 7 years now just not posted yet!
So my Cayman got the coolant pipe leak at the front only the one pipe but I'm planning to change all 4 flexi pipes at the front and drain the full system and put the same coolant back in as it was only done about 5-6 years ago by Porsche, I do have some to top up the system as some has come out and I will obviously loose some when draining. Assuming this is ok as it's lifetime isn't it?
So my main question is what else should I do/check whilst it's drained, should I check the water pump/replace whilst the coolant is out, my cayman is currently on just over 60k miles and nothing has been changed.
Whilst I've got time I'm planning to do a full service myself and a bit of an overhaul.
Thanks for any advice.
Rich
Rich
