Rather disappointed to discover the time in my 2021MY Macan GTS hadn't changed from when the clocks went forward 1 hour last weekend. []
I checked the settings in the Multifunction Display, also those in the PCM and both had been checked at "Auto", but were only recording GMT. I had (wrongly as it turns out) assumed the time would be adjusted automatically for BST - apparently not. []
It seems necessary to disable the auto settings, then adjust the time manually. At least, that's the only way I can see of doing it. Perhaps someone has another suggestion?
Only a minor niggle I know, but in this day and age, it's perhaps surprising clocks in the new Macan can't keep pace with the actual time of day!
