thanks Adrian.
By burped do you mean excess coolant has come via the bleeder value to cause the puddle ?
adrian55 said:Hi, Adrian , Could the problem be caused by faulty coolant(radiator) caps. I had similar problem on my 981 - changed cap in boot and got an independent garage to change the one under the engine cover .Yes there is one there as well which used to cause problems in 987s and 986s . Hope you solve issues ok .
Adrian
