A quick, hopefully simple, question.
The short link from the wiper crank to the driver's side wiper keeps falling off the ball joint on the wiper shaft because the plastic socket is worn. I bought a replacement arm.
Do I need to remove the wiper assembly from the bulkhead to fit the new linkage (including also the vent fans and housing) or can I just lever the new linkage onto the ball joints with everything insitu? Any advice would be gratefully received.
Thanks in anticipation
Mark
Mark
