Hi all,
Just moved from my 05 997 C2S to an 07 997TT Sport Chrono Tip today. Picked up from an indy and have a few questions issues that I hope you can shed some light on.
•Front fog lights not working. Looked in the fuse box but there wasn't a fuse indicated for front fogs in the leaflet
•Light switch set to HOME but when I lock / unlock the car the lights don't come on as they should
•In the Sport Chrono part of the PCM under individual options the DRL is set to yes but they don't operate
•Should side lights illuminate ALL leds? Only one outside on each side illuminates
I think the PCM has a big issue....
•Map DVD is 2004, is that correct?
•Shows NO sats found under status
•Shows incompatible software warning at the bottom briefly
•CANNOT change the time zone - this option is greyed out. Change the time on PCM (but that doesn't change the time on the dash). Showing GMT -3:44 wtf?
•On the dash display RADIO is not an option for the centre display - only phone
I have checked the sat nav gps antenna connection under the bonnet by the filter. This is secure. I have done a factory reset and the 148 option several times and also removed the PCM fuse for 10 mins all to no avail. I think the PCM / dash aren't really connected if that's possible.
The sat nav WILL look for a display a route but from the last known destination which is where I picked it up.
Also, there is no PCM manual. I have found one online but it doesn't contain the Sports Chrono option. Anyone know where I can download one?
Thanks in advance for your ideas and info.
Rob
Rob
