In a traffic queue, there's no need to keep your foot pressed on the brake. [
If you press a little harder, the system will initiate the hold procedure, "HOLD" will light up on the instrument panel and you won't then need to sit there with an aching foot.
When you want to move off, just press the throttle pedal as usual and away you go. [
