1st gear a bit stiff?
- Thread starter circleace
The other stupid question - the gearbox also baulks when the revs are high for the gear, even if it would leave it below the red line, eg so a high rev change from 3rd to 1st if 1st was over 4k revs it would require determined effort to get it into gear.
Failing that it could be the clutch cable going - there are two cables 1 for forward and back, one for left to right - if either or both are nearing the end of their life it can result in difficulty getting into gear, in particular 1st. The cables are a carry over from the 996 and the same design is used in the Boxster. its not uncommon for failures early in the life for all three models.
Presumably you mean gear box linkage cables, Tom? Clutch is hydraulic, non? As the clutch has just been changed are you also sure you are getting full depression when trying to engage 1st?ORIGINAL: okellyt
ORIGINAL: tscaptain
TS - Yes, loose terminology on my part. Gearbox Linkage Cables is the one.
Circleace - best plan to get it checked out, if nothing else to put your mind at ease.
Is that the flower show or the pensioners?[ORIGINAL: circleace
Chelsea man myself!!
juliany27
ORIGINAL: tscaptain
Chelsea man myself!!]
Thanks Alan for your support - the Chelsea team will need and wear it all the rest of the season.
As for Chelsea.....well for all you football guys on here....WHOS TOP RIGHT NOW???
Wills
ORIGINAL: garyw
Mines never been the smoothest of gear selections in 1st.... hot or cold and certainly more so with the sports shift/short shift
Maybe you should of got BMW for that [&:] []
garyw
They have awful gear changes Gary believe me! I too have the short shift and sometimes it refuses to go into first so I have to select second and then reselect first from that position other wise she just won't engage.
...and I also support Chelsea [
Wills
ORIGINAL: circleace
Is that what you do!! Collecting car later on and will try that!!
It occurs mostly when coming to a rolling stop, say at the traffic lights when I try and engage 1st sometimes it just doesn't want to know I've found that selecting 2nd then pushing into 1st works. But I have a bad habit of putting the car in neutral and coasting the last few metres so that might be the problem rather than the gearbox's as it happened in my m3 as well.
ORIGINAL: Wills
ORIGINAL: circleace
Most manual cars I have driven 1st is almost impossible to engage until you are at a complete stop. I can sometimes get 1st in gear when coming to a stop at about 2-5mph but you have to keep pushing the gear lever forward until you slow enough for it to go in.
