ORIGINAL: nick_968
ORIGINAL: 333pg333
While I agree with Nick in principle (and practice), I think it's still do-able on a less than 'Kabillionaire' budget. Both Mike's and Markus' builds went very well until both motors suffered due to increase boost. Markus had actually sold his motor by then so it wasn't actually he who had the accident. Mike couldn't resist turning up the wick. Now it's possible that both of these motors may have been weakened over time with forced induction but I can't be sure. Markus reached somewhere near 500bhp on his so lets assume this is possible! You could also buy some custom Wossner pistons for approx. 700GBP. Rods are not too expensive either from the same maker if my memory serves me correctly....it does beg the question....
Questions for you Pat.....
1. On average how much more in % do you spend on a project than you originally budgeted?
2. How easy is it NOT to turn up the boost?
3. Add the rods, the pistons and your into the same territory as any other 3.0 build and you know where that ends right?
[8D]
1. Too hard to say, but it's always a fair bit more. The only thing I'd say is that there is a lot of info out there to make more of an accurate speculation on overall budget, that the % increase over initial numbers may not be so much more....it's just that the original budget may start a bit higher than you desire.
2. I guess this is user determined. Some guys are pretty self disciplined, and perhaps more on this forum than others, but I agree that temptation is great to just squeeze a little bit more out of it. Having said that, you can set in place alarms and failsafes too.
3. Not necessarily...but again, yes, this can happen. My mechanic is going to try a reasonably cheap version of a 16v turbo project with an S2 motor. He's ordered the pistons & rods (Wossner), SFR intake, and will use his Vitesse Maf & piggyback to control it. May even use my old Stage V turbo. Obviously being a mechanic he doesn't charge himself a labour rate and we already had the S2 motor from a Japanese LHD import so while it's not going to cost him a lot, it would cost Joe Public quite a bit more.
