It's not my day today, at least as far as the 993 goes.
i) Decided to take it out for a quick run. Felt the cabin needed to be a bit warmer, so turned the heater thermostat up, resulting in the windscreen misting up completely within 30 seconds. Had to pull over to the side of the road to let the mist clear as the screen demist did its thing.
I've noticed this before - if the temperature's turned up I get screen misting for a while. Thoughts welcome.
ii) Engine oil temperature gauge has suddenly stopped registering anything. It has flickered momentarily off the "powered off" position, but then dies almost instantaneously. Does anyone know if there are any weak spots in this circuit (i.e. sender, wiring, 12V supply, instrument itself?).
iii) Most alarming - the car's developed a misfire and loss of power. It was serviced only a few hundred miles ago and seemed fine since. It seems to me that it's possibly running on one distributor - any quick tests for this? (eg relative position of rotor arms?). Otherwise it's probably a three week wait for local indie to fit me in. (Essex)
iv) Cussed rear wiper arm has snapped clean off at the point where the upper (on top) arm joins the part where the wiper blade fits into.
The 944, meanwhile, continues to run without incident....
Nick
Nick
