Jonathanw, like you I have owned Porsches over a number of years and I even restored and maintained them myself at one time, for the most part using O.E. parts though not always, as there can ever come the time when the cost of keeping an old Porsche on the road can cost more in parts than it might be worth, more so when air cooling was left behind and market values altered...?
Today and for me personally the idea of paying out for an engine or gearbox replacement on my 991.1 is thought to be best avoided and the costs in OPC servicing to maintain the extended warranty is on balance of probability thought by me to be worthwhile for ME... Were it not for the availability of the Porsche warranty, I suspect I might have stuck to air cooled.....Each to their own.
My thinking relative to electrical safety and driveway charging was not so much related to charger protection but more relating to animals and humans, in that possible contact with normal household electrical supply voltages can be life threatening..
While modern homes may have have earth leakage protection circuit breakers on some circuits, it seems possible that older houses may have similar breaker protection for external circuits for lawn mowers and the like, it seems that there may be many homes without any such protection, thus a 240 volt flex strung out down the drive may present a degree of risk of a type worth assessing...? I think if you accidentally fry the postman the neighbours kids, or dog/cat/bunny wabbit, there could be potential legal issues..!
For those with older houses, it is possible to buy an earth leakage circuit breaker (ELCB) that plugs into a UK standard 13A socket, to which one can then plug a charger into.... However that is no guarantee of adequate protection, as the EARTH to the 13A socket has to be proven to to be sure the device operates as expected, if the supply lead TO the charger is to be considered protected..? I suspect most ELCB`s will have a test push button on them which SHOULD test the effectiveness of the earth connection TO the ELCB, by tripping the breaker when the button is pressed..?
As for ANY additional non O.E circuit connected to a Porsche with an electrical issue hopefully covered under warranty, even just a loose socket lying in the Frunk or elsewhere permanently wired in with nothing connected to it... Hmm..?
You have a strange electrical problem sir..? What is this connection for..? Ahh, a charger, well now it is just possible sir that your charger may have operated with some sort of temporary fault and generated a voltage or frequency which may have upset your Porsches sophisticated electrical system to some degree .....?
I guess at that stage your skills in negotiation might be under a bit of pressureto achieve a desirable outcome..?
