sidicks
Am currently in Yorkshire for a wedding which has provided a nice opportunity (280 miles each way) to run in the new Bridgestones referred to in a different post!!
I did have an unfortunate incident where I nearly ran out of petrol as 3 garages listed on the Sat Nav turned out not to be there (probably due to the amount of new construction on the A1(M) these were temporarily closed down).
With zero miles already showing on the trip computer, we then used the Sat Nav POI to head along the A61 to the nearest petrol station which was then closed!!! By now I was really panicking, but we asked a local who directed us towards the local Tesco garage, a further 2-3 miles away.
By this point I was wondering when the car would finally stop, and therefore how long a walk I faced, but we made it all the way to the garage without any spluttering which was a welcome relief. I sensibly decided that this wasn't the time to be snobbish about only using Shell V-Power, and Tesco 95 was considered more than adequate!!!
I manged to fit nearly 63 litres in the tank, the most I've ever had to put in the car.
When my wife read the drivers manual, it said that the fuel tank is 56 litres, with a 10 litre reserve tank. Does this mean that the trip computer bases your remaining mileage on the main tank only, so once you hit zero miles, in practice you have 10 litres spare which should be enough for 40+ miles??
I don't plan to cut things this fine again, but it would be good to know what the real situation is!!
I believe that due to the 4WD, the fuel tank is a slightly different shape to that in the C2S, but not sure if this makes any difference to the reserve tank?
Sidicks
Sidicks
