Hey Guys. Well it has been a while since I've been on here.
At last I have decided it is ime to get rid of the smoke screen that follows me around (especially when I nudge the ton). It's time to stop the oil injection onto the exhaust and get an engine rebuild. Any suggestions on what I should or could get done (possibly with a minor mod or two)?
Currently thinking f doing the following:
- Hydraulic Chain Tensioner - install
- Gaskets all around - Replace
- Rings - replace
- Hone the bores
Also while she is at the surgeons:
- Heater butterfly valves - replace
- Air controller cables in dash - replace
Any other ideas?
Another question as well - what amp fuse should be used for the AC? At present there is a 16amp (which I burn out when he AC is on speed 2 or 3). From what I can ascertain it should be a 25amp. Is this right?
I'm hoping to get the work strarted on Monday.
Cheers[8D]
- Rings - replace
- Hone the bores
Any other ideas?
Cheers[8D]
