Hi,
More updates on my 930 problems!
Sorted my cigarette lighter issue now (not working) and it was simply that the feed pin on the back of it had come off. Pushed it back in and tested for 12v and a good result: FIXED.
Whilst piddling around with the interior I noticed that the drivers seat backrest wasnt moving forward (it did at one point) so next job was to fix that. Out came the seat and took the seat switch out (watch the ball bearings if you try it). The switch contacts looked very dirty so out of the toolbox comes my trusty fibre pen. A bit of cleaning later and the seat stuffed back in the car and wired up I tested it. As if by magic: FIXED.
The list seems endless because whilst I was getting to the back of the cigarette lighter behind the blower motor etc I thought I'd take a look into why my fresh air blower doesnt appear to work. Hmmm, what on earth can that be....looks a bit burnt to me. More examination and I see a completely burnt out black wire. Following this along I see some more wires have been damaged / melted. Two brown earth wires which connect to the back of the clock and the earth wire which piggybacks with another wire on an earth spade on the back of a dial. A white with green wire also looks a bit rough which goes to one of the dash bulbs. I think because some of the wires are earth wires everything seems to be working but the black wire has GONE.
What a saga I'm having....What makes it worse is that the black burnt wire goes into a "knuckle" in the main loom behind the dash and its flippin awkward to open the wrapping. I'm thinking this wire is probably the feed wire to the blower so I go to the fusebox and take an educated guess as to which terminal it could be fed from. Hmmm, how about the black wire which is fed from the same fuse as the cigarette lighter. What do you know, the wire "bells out" from the black wire connected to the fuse and also the end I found on the burnt wire behind the heater indicating continuity.
Intrigue makes me think I had better just start unwrapping the loom wiring until I find what appears to be a "normal looking" black wire, ie, one that isnt completely burnt. I think I might end up doing some replacement wiring to sort this little lot out. The thing I'm thinking of is why did it get to this anyway. I'm kind of thinking the wire took a bit too much current to the point of meltdown. My luck is that I'll replace all the dodgy wiring and find the blower or something heats up the wire and I end up in a circle. Maybe it'll be a good idea to test the current flow before putting everything back together!!!
Well in fairness I'm enjoying these little jobs albeit in a funny sort of way.
I'll post as I continue this saga, lol.
Chris
