944 Chip Design.
- Thread starter barks944
Will have a dig about for that info at the weekend.
It will be good to see this work, or do as I did blow your Lux up by trying to stay with faster cars then buy a turbo and you will be the faster car!!
sawood12
ORIGINAL: barks944
This may sound a little backwards but anyhow here I go...
The porsche 944 already calculates air mass using the AFM and the air temp sensor. This means I cant plug in a device that outputs a voltage representation of air mass as the 944's DME will convert this signal into another value using its air temperature sensor. This means I cant use any MAF sensor that outputs air MASS without modifying the DME's code or perhaps manipulating the temp sensor. Another Idea would be to use a hot wire MAF which has a temperature compensator in it to convert back to air flow before sending a signal to the DME. The 944's DME can then happily re-calculate the air mass with no detrimental effect. This would give the improved throttle response of a hot wire air flow sensor without the hassle of changing the DME's code. Does anyone know of a MAF that would fit this description and would be suitable for use on the 944. I believe the 944 outputs a controlled 5v to the air sensor and recieves a signal back from the AFM in the range of 0-4.5v. It uses the ratio of these voltages to calculate air flow.
I think I read somwhere that at high air flows the 944 DME calculates air flow based on RPM and throttle position. Anyone know anything about this?
Edit:
Perfect: http://www.carlton24v.co.uk/afmmaf.htm
OK, the AFM does have an air temp sensor, but it is only sampled once at startup and is not used continuously. The mapping is compensated for the temp measured at startup. Therefore the ECU is not calculating mass flow.
Also the relationship between the 0v - 5v output of the AFM is not a linear one with respect to the air flowing through the device. As the airflow increases in speed the barn door opens, and as it opens it offers a reduced frontal area to the airflow, therefore the barn door opens at a differing rate to the increasing speed of the airflow.
Also at about 4krpm the barn door is fully open and so further calcs by the ECU are done on the basis of RPM and throttle position.
What you're after are features that are already available on severeral existing MAF kits. All these kits (well the decent and more pricey ones anyway) have a small computer that calculates the mass airflow and outputs a signal that can be interpreted by specialist code on the DME (i.e. not standard Bosch Motronic AFM code) so you are not tricking the ECU into thinking it is still seeing an AFM, you are converting the ECU into a device which is actually calculating the true mass airflow.
You can tell a proper MAF kit that calculates true mass airlfow if you don't need to re-chip it to suit varying boost pressures i.e. the Vitesse kit which is $1250 plus $850 for the Piggy back that offers you real time tuning capability with data-logging, closed loop AFR (either from the stock lambda sensor if you have it or from an aftermarket wideband sensor if it is a pre-cat car) and MAP based ignition mapping.
I'm not trying to put a dampener on your aspirations as it would indeed be an interesting project, but I wouldn't assume it is simple or easy in any way or necessarily cost effective. Given the time you'd need to invest and the probably cost to get it all working you'd probably have been better off with something like Megasquirt or the Vitesse kit.
One possibility (though i'm not sure if it has ever been attempted) is to use a 968 ECU and MAF sensor, as the 968 did have MAF.
Isnt that essentially a mass flow calculation...You are taking temperature and therefore density into account...Maybe you mean its not calculating true mass flow but its somthing analagous to it.
sawood12
But anyway i'm one of these people who left my toolbox alone a long time ago and has become very lazy and will just go and buy an already established kit!
Tony
