Neil Haughey
ORIGINAL: 944 man
Even the floor is different Neil - where it covers the transaxle (and the redundant bellhousing in the five speed cars).
Good point, I have a seam there that goes straight across the shell and needs a little treating for a touch of corrosion on the edge of the seam. Not sure but I don't remember seeing this seam on the 44 shell.
A point about weight, something I have talked to Kev Eacock about is the construction differences, the 68 looks and feels much more solid around the bulkheads, areas where the suspension mounts but conversely it definitely seems more susceptible to bent floor syndrome because the floor is no stronger then in the S2, perhaps weaker. I don't know for sure but I suspect the 68 shell is heavier despite having less steel at each end.
968 race cars are faster then S2 race cars despite the 968 having to run 225 wide tyres as opposed to the S2's 245 wide tyres (PCGB Championship specs), and much more weight. No matter how you cut it the 968 is a faster car.
