ORIGINAL: edh
ORIGINAL: appletonn
And finally...!!
Looks like you've had all the vac hoses done with the LR kit - what sort of boost control are you running? - hard to spot in the pics. It also looks like the FPR is standard? (3 bar ones I've seen need a different hose as they don't have threaded fittings)
Well, it should be a 3 bar one as that is what came with the rest of the LR kit, including the manual boost controller and 3" downpipe etc - currently 16psi, I think.
Kit all fitted at RPM for PO, some 5 months ago so I will pull out invoice and check![
It's a RPM tailpipe too as the LR one was a 4" system and considered too 'chavvy' by RPM, apparently!
