944 S2 Bilstein Inserts for crimped front struts
- Thread starter RS2000CUSTOM
MartinRS2K
ORIGINAL: Eldavo
I know of someone on this forum who is amazingly restrained with regards to Oli Snellman - far more than I could/would be.
I can't recommend anyone deals with him I'm afraid.
He's been more restrained than I would have been. Personal issues aside, it's been over a year and still excuses [
RS2000CUSTOM
ORIGINAL: robdimond
I would be very interested in this... possibly the DIY option. Where is the best source for the inserts and how much?
ORIGINAL: TTM
It's nice to see someone in the UK who may now be ready to supply converted struts.
ORIGINAL: 944 man
I agree - I messaged Olli Snellman but he didn't reply.
It was because I couldnt get any reply from Olli that i decided to make my own
I seem to have a mix of people registering an interest in complete exchange strut or the collar only so I am going ahead and costing for both options
RS2000CUSTOM
ORIGINAL: Richair
For those people who are handy you can use chopped early or golf mk1/2 strut tops which fit inside the 944 struts and can be welded in a similar way []
I did consider this method
RS2000CUSTOM
The original unit has a bump stop under the protective gaitor but its internal bore is too small for the new Bilstein unit
So a quick call to Bilstein UK and they have confirmed that the insert I have has an internal bump stop built in
RS2000CUSTOM
RS2000CUSTOM
Previously my car had a judder upon applying light application of the brakes - NOW NOTHING !
(I feel this was caused by excessive movement at the top of the casing where the strut exits the casing)
Slightly harsh and a bit clunky over rough road surfaces - NOW NOTHING !
Intermittent thud from O/S/R - NOW NOTHING !
Virtually all body roll has gone and the car feels very sure footed without any harsh or excessively hard ride quality
Bilsteins - Plug and Play or Fit and Forget ??
Too right they are !
I have checked the camber and I need a small adjustment on both sides to obtain 0' +/- 20' 1990 on S2 models
TTM
Well-known member
I see you are still running the standard springs (pink dots) on your S2, now that your are running proper dampers I can only suggest to consider upgrading to 968 CS springs (blue dot), as they are slightly stiffer and will lower the car just a bit, which in my humble opinion should make a more comprehensive package with the new dampers.
RS2000CUSTOM
ORIGINAL: Diver944
Looks great Dave, so glad to hear the ride matches the looks!
Enjoy [8D]
It certainly has made the car "feel like new" again
ORIGINAL: TTM
Good job well done!
I opted for new standard S2 springs as initially I was going to go the lowered route but as the car sits very level and ride quality is now excellent I think I have done the right thing and kept it standard height / spring rate
