peanut
could you just give us all an update where things are at the moment re trying to start the engine .
If you remove the HT lead to the distributor Is there a spark on the HT lead ?
When you try start the engine are you pumping the throttle ? it should be started with zero throttle.
Have you checked that you have 12v+ at one of the injector connectors with ignition on ?
Have you tried starting the engine using easystart yet ? what happened ?
Is the engine trying to start at all ie coughs splutters etc ?
I'm trying to build a picture of an engine that none of us can see or test.
