TTM
Well-known member
ORIGINAL: PSH
keep the 8 valve head Pete.. I hate 16 valves... no low down torque and far too much throttle needed to get going in comparison... ok for the race track when the engine is screaming it's nuts off 90% of the time but who wants that for a road car? not me...![]()
Not sure I agree with this. As far as I have observed the 16V head is superior to the 8V head by all accounts.
The inlet valve area of a 16V head is higher than an 8V head with a 51mm valve, which is very large, in fact so large that the outer edge of the valve may move worryingly close to the cylinder wall, which could possibly alter a flow figure that was initially excellent on a flow bench.
Friend of mine uses 52mm valves in a 102mm bore engine, and his heads flow a staggering 300cfm each, but that is on a pushrod V8 engine where the plane of the sliding inlet valve is not parallel with the plane of the cylinder, and as his inlet valve slides open, it moves towards the center of the cylinder, giving enough room to the air to flow more or less evenly around the valve, whereas the plane of the inlet valve stays parallel to the plane of the cylinder on our engines, if you see what I mean. When increasing valve area isn't enough to improve flow, then we have a problem that only ace (read €xp€nsiv€) machine shops with lots of experience working on cylinder heads may solve.
Only reason most (me included) build 8V 3L engines is that most of the original hardware (inlet and outlet manifolds, etc) is reusable with little to zero modifications.
In my case, I just cannot justify building a 16V engine because I believe the difference in performance my not be big enough to justify the additional expense. However, if I were to do it again I would build a 16V engine from the start.
The irony is that the usual 944T enthusiast may initially find easier or more natural to build an 8V, also because Porsche did it themselves, but may find out after it's done there is actually little additional effort needed to build a 16V engine that will perform (and sound [
