I'm about to embark on the rebuild of my 944T's engine. The engine is from a 220BHP car and will have a rebuilt K26/6 turbocharger (probably), lightly modified cylinder head, adjustable cam gear, maybe 3" downpipe with 3" front section, 2.5" rear section, stage 1 intercooler, late 944 NA cam and LR wastegate. Injection system will hopefully be my new modified motronic based system although probably standard with promax lvl2 chip to begin with. You can't beat the experience of those that have done it before so I'm going to post what I think I need and hopefully people can spot anything I've missed.
Widefire headgasket set
Short block gasket set
front engine seal kit
intake and exhaust gaskets
belts
Clutch Kit
Clutch release fork
9 Flywheel Bolts
9 Pressure Plate Bolts
T/O Bearing Guide Sleeve
Rear Main Crankshaft Seal
Clutch Fork Bearings
Pilot Bearing
Alignment tool
Clutch Fork Shaft
Engine Oil Thermostat and Seals
Air Oil separator o-rings
Turbo thermostat?
Thermostat
Connecting rod bearing set
Main bearing set
balance shaft bushings and bearings
Piston pin clips
Piston rings
engine block freeze plugs
oil pressure relief valve seals
connecting rod nuts
Loctite 574
Liquid Moly Assembly Lube
Any input appreciated! Including things to watch out for, top tips, cheapest places to buy etc etc!
Any tips on rebuilding a TT? Think the bearings are gone in mine....
Tom
belts
Clutch Kit
Clutch release fork
9 Flywheel Bolts
Pilot Bearing
Alignment tool
Clutch Fork Shaft
Turbo thermostat?
Thermostat
Main bearing set
Piston pin clips
Piston rings
connecting rod nuts
Loctite 574
Tom
