ORIGINAL: MoC2S
ORIGINAL: Porker993
I heard last week that the V-ram cars have a different gearbox, with slightly taller ratios, due to Swiss noise regulations ?
A V-Ram owner driving my early non V-Ram car found it noticeably higher geared.
Maurice can no doubt confirm ?
Not quite that simple .. US and Swiss cars only ever had the one gearbox .. G50 / 20
3.818 / 2.048 / 1.407 / 1.118 / 0.921 / 0.775 with 3.444 final drive
Until Dec 1994 when 5th changed to 0.928
Early RoW cars had the G50 / 21
3.818 / 2.150 / 1.560 / 1.242 / 1.027 / 0.820 with 3.444 final drive
Until Dec 1994 when 5th changed to 1.024
Simple comparison = same first, then G21 has slightly shorter gearing .. 2nd to 3rd biggest difference. Torque spread of VRam easily compensates ..
Later RoW cars had the G50 or G64 (4WD) / 20
but MY '96 cars had 3.818 / 2.048 / 1.407 / 1.118 / 0.929 / 0.775 gears on a 3.444 final drive
'97 spec G50 / 20 allegedly has a 5th of 0.928
TT was 3.818 / 2.150 / 1.560 / 1.212 / 0.937 / 0.750 on the usual final drive - looks pretty damn good ..
RS had 3 different (again) G50s - taller firsts (3.154) much better for the track
Eg G50 / 31 has 3.154 / 2.000 / 1.522 / 1.242 / 1.024 / 0.821
Its certainly not just geasring but characteristics of the engine. The Service Information Technik volumes confirm that M64 / 21 (VRam) engines were introduced with the MY 96 cars, ie August '95 build. Of course, whatever stock would be used up .. [8|]
Tomorrow's quiz will be - what are the redline speeds in each gear for all variants .. [8D]
cheers, Maurice [
