993 RS tyre pressures on track
- Thread starter micksummer
PhilRS
ORIGINAL: PhilRS
Roll bar setting for Spa tend to be (for a 964 RS) middle in the back (not full stiff) and full stiff at the front (or one off full stiff). Though it is ultimately down to driving style, these settings are those used by most regulars, for neutral behavior in the long curves, where most time is gained. Paul's will provide great turn in in slow to mid-speed corners but could be "interesting" in Pouhon, Blanchimont and Raidillon []
Does it relate directly to a 964?...With the different rear suspension on a 993 (more compliant) I woud expect to run a stiiffer bar setting at the rear than on a 964.
Andy Tims
ORIGINAL: vic cohen
Have heard great things abt Cadwell , just along way for a day out ..............getting very lazy in my old age
P1ss poor excuse Vic [
![C731F72EAEB74912A0B37DC678A4F7DC.jpg](https://www.porscheclubgb.com/forum/legacymedia/upfiles/154/C731F72EAEB74912A0B37DC678A4F7DC.jpg)
micksummer
PhilRS
ORIGINAL: clubsport
ORIGINAL: PhilRS
ORIGINAL: vic cohen
i THINK HE MEANS SLACK THEM OFF ,EVEN TAKE REAR OFF IN THE WET!..................................does nt matter wat they are when ur on Belgian flint!!
this is very true vic.....you get a very good vantage point for the correct line through pouhon when sitting in the gravel trap when the dust finally settles of course !
with all the re-working at spa I wonder if they have managed to remove the brown stain off the asphalt at the top of eau rouge after your little stalling pirouette, they might even have found bits of your 'box down at bus-stop, probably worth checking with course marshall when you get there........
thanks for the info on ARB's.....
paul howells
These setting work fine at spa on Mich cups or slicks, race chassis or standard 993rs.
If racing at spa or race car for track days etc,even more important for the fast corners is less front toe and more castor,which keeps a 993 even more stable through the fast corners.
I would drive out there on the settings i have stated for dry,and then alter if you need to if its wet,or just drive carefully in the wet.
Ben vic likes going round and round
Have a good time there
ORIGINAL: vic cohen
U never did show any respect for the aged .........................mind u suppose u do look after Tim!
Tother way round.... Usually have to pull his head out of his dinner when he has his little nap.....
Andy Tims
ORIGINAL: tim court
ORIGINAL: vic cohen
Yeah - thanks Mum
micksummer
ORIGINAL: paul howells
Dry roll bars
rear full stiff,front ,one off full stiff,if understeering,soften front one more hole,with rear still on full stiff.
Wet
Front full soft,rear full soft,
or on the rear disconnect one side, will cause understeer at limit of grip,instead of over steer,safer for a slippery track.,until you get used to your car etc
Cable tie drop link out of the way.
Changed th anti-roll bars from middle frt + back, to rear full stiff, frt one from full stiff. Will try it out in Spa next wk.
BTW, anyone here going?
Do I need to soften them for the Ring? as I'm doing the Manthey Ring trackday 2 wks later.
micksummer
The set up with full stiff rear, one off from full stiff front seamed to work real well there when the track's dry. In the wet even with adjusted pressure it's like driving on ice rink! The rear was dancing around and the front wouldn't grip. The whether was changable for the whole of the 2 days, so in the end I just drove real slow in the wet concentrating on learning the lines, and save the speeding bit for when the track was dry.
Had a massive spin on Blanchimont, only on the out lap so wasn't concentrating on the line too much and turned in way way too early, ran out of black stuff on exit of B2, touch the green stuff and the car started spinning, missing the concrete wall, twice!! Luckily no damage. All caught on film.
The spin caused the rear tyres to blister, and since they're yrs old anyway I decided to change them to Toyo R888 on site ready for day 2.
The Toyo (or may be just new rubber full stop) felt much better even in the wet, and the car felt very very stable on fast corners with that setting and pressure was 32 front 36 rear hot. Just need to learning how to drive properly now....
Going down Eau Rouge, takes some nerve to turn in without even lifting! (in the dry of course!) :
![DSC_9166.jpg](http://i140.photobucket.com/albums/r23/micksummer/Spa/DSC_9166.jpg)
paul howells
Its false economy to track on old tyres,it can end in tears,or is that tyres!!
Spinning on out lap,thjats as bad as cooling down lap ,good to see you missed the concrete.
micksummer
paul howells
In the wet,the poor grip from old tyres gets highlighted,and in the dry they kind of feel ok.
Its like when setting a car up ,and getting feedback about what the car is doing,should be on new or fairly new tyres.
