996 Complete Power Loss >> Details inside...
- Thread starter Paul James
Black80XSA
Paul James
Paul James
Don't worry, you can be sure of that. I've already made a major fuss over the phone, moaning and whining about the way they fitted the springs, about the power loss, that they can't know what they're doing, and that if the car's not perfect after Saturday they'll have a bad name all over the internet. [8D] [ORIGINAL: NXI20 As you had it installed, I would say it's incumbent on the installer to ensure that the installation doesn't ruin your MAF or anything else as a consequence. Go back & make a fuss []
Paul James
Diesel130
I think they have that already now !! ;-)ORIGINAL: Paul James ... and that if the car's not perfect after Saturday they'll have a bad name all over the internet. [8D] [] [8D]
Paul James
Well they certainly have over PCGB Forums! [ORIGINAL: Diesel130I think they have that already now !! ;-)ORIGINAL: Paul James ... and that if the car's not perfect after Saturday they'll have a bad name all over the internet. [8D] [] [8D]
Paul James
I'm still not sure if the MAF Sensor is gone though. The car was behaving itself after I turned it off and back on, and although I wasn't footing it completely, it was still taking a bit of a thrashing up to about 5500rpm...ORIGINAL: Richard Hamilton It's a Hot-film MAF, not Hot-wire. You can try a contact cleaner, but in my experience it's a temporary fix (if at all). If you want someone independent to read out the fault codes, drop me an email as I can do that for you.
Black80XSA
Paul James
Paul James
5522 is a CAN communication error, but it only applies to 2002-on cars. You sometimes get PSM errors if the MAF is on the way out, as the signal it generates is implausible to the PSM based on the DME outputs. Your car does have a CAN-BUS.ORIGINAL: Paul James Error code 5522, they say it was a CAN error, but they also said that my car doesn't have CAN, so they don't know why it came up. When I looked at the screen it was under the 'PSM' section... Also on a non-Porsche diagnostics kit, the error came up as PSM. Another thing that I noticed when I was thrashing it up a hill the PSM turned itself off.
Paul James
