997 C4 and C4S
- Thread starter Guest
ORIGINAL: Spizz Oil
My OPC says that these will only come as widebodies. Is this the case. Would be a shame.
Spizz
Reading the test reports so far on the bog standard 997 "S" 2 wheel drive with the latest and greatest in electronic suspensions can't really see the need for a 997 C4 narrow or wide bodied [
*****************************************************************************ORIGINAL: Spizz Oil
In Scottish conditions, can tell you that C4 feels so much more planted in rain, snow and ice.
Spizz
Surely not at the legal speed limits weather conditions permitting of course
I've never been entirely convinced about the merits of 4wd on a sports car.
If I lived somewhere with treacherous winters I would rather put my faith in the electronic driver aids and an appropriate set of winter tyres. Or, better still, l'd have a proper 4x4 for such conditions
4wd on the turbo cars is not just safety, if helps to get the power on the road, since 560-620 Nm is quite a lot of torque. Although in the dry the Carrera GT makes do with just the rears and has more torque (but wider tyres). The rear drive only GT2 struggles when it is not dry. In the real world, 4wd is quicker and more secure.
On the non-turbo cars, I am not convinced (after 22K miles in the C4S). I can't make up my mind - I think I would prefer rwd.
I thought that people bought C4S's because they liked the 'wide-body' look - otherwise why pay the extra for a 'sports-car' that is heavier and less aerodynamically efficient? Or are they trying to give the impresion of owning Turbos?
I agree with the Hamster's (Richard Hammond, that is) assertion that the C2 is the better car, on a 'bang-for-buck' basis, as the the C4 is more expensive, but not necessarily more fun! Predicating the purchase of a C4 on the grounds of more useability in adverse weather seems a little absurd, given the amount of effort that many owners appear to go to keeping their cars dry.
Personally, I still think that the two-wheel drive car has superior steering, one of only two real advantages of the rear-engine architecture. The other being, traction., of course.
Perhaps the C2 should have the wide-body!
Thereafter it is down to personal preference.
If you want an open top, go for targa or cab. If you want auto, go for tiptronic. If you want 4wd, go for a C4. If you want a semi-track car, go for a GT3. If you want a more aggressive look, go for a C4S. If you want more performance, go for a Turbo. If you want your 911 with all the bells and whistles, go for a 996 Turbo Cab with power upgrade and tiptronic!
None of this necessarily makes a better car (afterall, with 911s, less is often more), but it enables all tastes to be accomodated. And, as Porsche want to sell more cars, they have to appeal to a wide audience.
steve lyden brown
SGLB
When the 996 C4 was introduced (about a year after the 996 C2), the contemporary road tests and reviews concluded that it was a safer handling car than the C2.
Some people wrongly assumed that this was because it had 4-wd. In fact, it was the newly introduced Porsche Stability Management (PSM) that made the difference. This then became an option on the C2. It is PSM that makes the 996 more secure not 4-wd.
Of course, for someone like you Steve, who has clearly driven at Le Mans and the Targa Florio, PMS is for whimps and you would drive flat out in all conditions with PMS permanently switched off.
And, yes you can get a lot more pheasants in the front of a C2.
I think you and Steve are actually agreeing[
I read Steve's post (above) as meaning the PSM may help overcome to some extent, the disadvantage of not having all 4 wheels driven.
Grant
C4-
negatives... slightly heavier, more wear & tear on front tyres/brakes, smaller boot, price.
pluses........ extra weight over front makes the car feel more tied down & balanced, cornering traction improves as the front wheels pull you round for an even faster exit, particularly in the wet, less understeer at the limit.
Because of the price difference vs extra benefits, if I was buying new I would go for a C2, but as the prices are MUCH closer second hand the C4 makes a lot of sense as it comes with PSM as standard & extra traction can only be good !!!
C4S
The C4s is a slightly different animal, it comes with wider track & tyres of the Turbo, the same 10mm lowered sports chasis as the Turbo & the larger 330mm all round disc brakes.
The combination of the wider track, sports chassis & improved braking plus the 4 wheel drive traction more than compensate for the extra weight involved & it is considerably faster & more "chuckable" than a standard C2 point to point. Add the wide body looks & you can see why it's offered the best residuals of the current 911 range (first GT3 aside) & why it has taken over from the standard C4.
The standard C2 is a great car (particularly when specified with the sports chassis) but so is the C4S, which is probably an even more rewarding drive. I currently have a TT, this definitely needs the 4wd.
The overall point I am making is they are all great cars & it's all down to personal choice, a C2 certainly isn't the poor relation, but neither should you believe that the C4S is simply all marketing hype, it's one hell of a drivers car !!!
alex.powell
alex.powell
steve lyden brown
I much appreciate your very well informed reply to my query. The technical element of your answer was just the thing I was looking for.
Insofar, as your inside knowledge of my racing capabilities and numerous wins are concerned, I can see that I am going to have to fire Max Clifford,since although I am not averse to the odd bit of favourable publicity ( such as my being seen in very fashionable nightclubs with quality totty on each arm ), I did tell Clifford that in order to avoid making my fellow PCGB members a tad jealous, I was very anxious to use my racing nom de plume when carrying off all those cups and medals.
Insofar as the quantity of pheasant that I can pack into my C2's boot, I have no wish to be thought to be a tad snooty, but who shoots pheasant when there are grouse to be had !
Ciao,
Steve.
