9M 993 RSR on track....
- Thread starter BlueNGT
Callum is a very good racer and of course was in compelte control of the car, but it was a track day where you can find all sorts of ability and equipment sharing the same bit of tarmac (not a test or race day) and i think he may have missed the Goltrack driver briefing!!!
Scott R
ORIGINAL: 65 mat
If you drove like that on one of Goldtrack's days then you would have Mellindi to deal with!!!![X(][X(][X(][&:][]
Ooooh.............yes perlease!![]
Have I missed something? Wot did Calum do wrong??[&:]
This is why I like Paddock club days with RMA or test days. You pass either side like in normal racing and overtaking car uses common sense, other car sticks to its lines. Fair enough though, not the place for a complete novice. The cars in this video seemed better than novices, even if they appeared a bit slow; there again many people look slow compared to Callum who is a bit handy.
ORIGINAL: jimmyslr
You can do most things on Paddock club days, but not on other RMA days I believe; this was the case in prior years at least. The idea is same as a test day (loosely) in that the responsibility is on the overtaking car to make a move that will stick without grossly hindering the car being overtaken. The car being overtaken should stick to lines and not try to do anything clever or unexpected.
Didnt know that - interesting middle ground for a TDO. A lot more like europe then.
johnny senna
ORIGINAL: RSR
It's not an RSR copy either. Genuine RSR's are narrow body. This car is based on a turbo wide body, so the bolt on arches are actually GT2 rather than the proper RSR ones. They are different parts.
Body wise its a GT2 replica, with RSR rear wing and engine.
If this is 9M's most recent creation, my understanding is that it is a RHD 993 RS shell that has had RSR/GT2 wheel extensions put on.
Talat
ORIGINAL: johnny senna
ORIGINAL: RSR
From memory I think it's a 993 C2S shell that has had the bits swapped over from a written off 993RS. Full build details are on RL.
paul howells
Alot of the parts are from a certain 993rs,but thats it.
Quite a few people think my rsr is a GT2 ,which is fine,because most dont know what it is,or that they even exist.The rsr as rsr says is built on a narrow body cup chassis,the arches are 25mm per side narrower and only runs 11 and 9 1/2 inch wheels etc
paul howells
I may be doing a couple of the gt90 rounds that are supporting the fia gt races
I am going to give the open a miss until things improve on track etc
Also racing a 1974rsr in the masters series and CER,first race spa may 8th
