A bit of DIY advise needed
Update time, cig. lighter replaced, a pain but worth it. Tilt sensor replaced, condensors and radiators renwed, alloys reburbed and front discs and pads also done.
I was about to replace the starter but I have noticed a weeping of oil from either the cam cover or possible spark plug tube. Is this a common thing? It's not dripping just a dampness so I'm not sure weather its worth the hassel at this stage to repair the problem as I'm sure that I would need to replaced to exhaust system if it had to come off due to rusty everything that's holding it together![8|]
And to think I sold a 5 year old boxster s with 15k on the clock to buy this![:mad:]
Spark plug tube leaks are fairly common on the 3.4 (the 3.6 doesn't have them). The exhaust shouldn't need to come off.
Check this thread: http://www.porscheclubgbforum.com/fb.asp?m=585801
Thanks Richard. I've cleaned off the oil and given the car a good run and I'm happy to report than no oil car now be seen. I don't think any action is required for the time being.
