In the recent months you may recall I have enlightend you all to my on going saga with my instrument cluster.
Summary : All instrument cluster dials failed without warning. Changing fuses and dissconnecting the battery failed to solve the problem. A new cluster was purchased. This worked fine for 10 days before failing again. Same problem all dials not responding but some lights come on now and again. Indicator lights fine and battery guage fine. The cluster has been repleaced under warrenty.
However before my Porsche specialist fits the new cluster both they and I want to find the route of the problem.
They have checked the wiring behind the cluster for any unexpected large currents, but couldnt find any. They then suggested removing the whole dash board and checking the complete wiring loom and if all else fails replacing it at considerable expense. Shocked that this could ultimately be the only way to solve the problem I asked for a second opinion from Porsche directly. They said they would probably remove the dash as well and check for a wiring problem since 2 clusters have failed.
My Porsche specialist said they could try one more thing which is that there are 2 electrical connectors that plug into the back of the cluster and maybe replacing these would resolve the problem. One problem Porsche do not sell these connectors seperate from the complete wiring harness, so a contact they have is trying to source the parts elsewhere. Now having to wait.
Not being mechanically minded or have the first bit of knowledge regarding the electrical system I not sure what to make of the whole sage and was hoping for some advice.
A reminder that I'm based in Dubai, with one OPC and one Porsche specialist to speak with.
