Advice?
- Thread starter DivineE
I think they may be 996 turbo coil packs, but a long time since we talked about them!
Tony
sawood12
ORIGINAL: 944Turbo
Rick did have a different MSD box before swapping to coil on plug http://www.cannell.co.uk/944%20Turbo%20-%2078.htm Not sure if the COP needed it or if there was another reason for the swap.
Tony
I seem to remember they are off a Suzuki motorbike or something like that as the thread and their length was right for the 944. They needed some form of modification to make them fit. They are definitely not 996 coil packs. Those things are huge and they wouldn't fit under the bonnet.
sawood12
http://www.cannell.co.uk/944%20Turbo%20-%2069.htm
ORIGINAL: peanut
when you say' ignition box' what do you mean exactly ?
Are you referring to the ignition amplifier which receives pulses from the ECU and provides the HT spark to the coil ?
A picture of the part would be useful for positive identification.
is this the part ?![]()
Ignition Amplifier? I don't have one of those - just an empty bracket. Why??
peanut
Here is a full explanation of what the Ignition Amplifier does below. Its failure is frequently the cause of a 'no spark' situation
'It contains the high current / voltage transistors required to drive the ignition coil and has a metal back for mounting onto a heat sink to dissipate the heat generated by it. The module has its own 12v feed, and ground, and is only linked to the ecu by two wires - one from pin 24 which is a reference ground and another from pin 25 which is the control line.
When pin 25 is low, the module is turned on and will be holding the coil -ve supply low to charge the coil. When pin 25 goes high the module will turn off and cause the coil to also instantly turn off, causing a spark to be generated. By delaying how long after the spark line 25 stays high, the dwell can be varied to limit unnecessary power losses at low rpm.
The actual coil current limiting is still controlled by the module itself though. The signal for pin 25 is generated by a capture compare unit within the micro controller causing an interrupt to instantly change the pins output level when the the timer value matches it. The ecu uses a transistor to buffer the micro output which is either shorting pins 24 to 25 or open circuit.
edited to remove reference to Ford parts
ORIGINAL: barks944
That thing is used to interface 0/5v digital logic with a coil. I think it can just ground out a coil when it gets 5v or somthing, so you don't have to put the current through your ECU circuits.
ORIGINAL: peanut
yes yours may have been re-positioned or have been located elsewhere originally. My car is an S2 which model is yours ?
Thanks both.
It's a 1988 Turbo S. It must be just be somewhere else on mine then.
This bit sounds interesting though.....
ORIGINAL:
On the P8 it is easy to implement a second ignition output on pin 26 which, when connected to a second ignition amplifier, can be used to create distributorless ignition. Pin 25 then fires cylinders 2&3 and pin 26 fires cylinders 1&4.
What does P8 refer to and how would one implement the second ignition output??
ORIGINAL: barks944
P8 is a ford ECU, probably used on cosworths...
Oh, ok.
I guess the same feature is in the BMW version - I believe some models of a similar era to ours actually had this enabled and ran twin coil packs. Wonder if it would be possible/what would be involved in adapting one....
Anyway, at least I now know what the bracket is for - nothing, it's just a shared inner wing part with the S2 I guess.
I can now go ahead and cut it off to make space for a big filter! [
Chop away! Looking forward too seeing lots of pics from your turbo swap!
