Hilux
If paint is well stuck to the metal then why remove it, simply flat it back to an accepatable finish and paint it. Its layers upon layers over the metal that get a good deep finish not the other way around where you spend loads of time on the metal but only a thin coat of paint. The metal needs to be good but you look at custom car makers and they use loads of filler primer and highlight coats and get that right by repeat rubbing down until a highlight coat is evenly worn off so no high/low spots whatsoever.
