scam75
Well-known member
Hello again
One for mildly tuned turbo users this time. I am currently running Promax L2 chips which I am happy with. I also run a scivision maf so I do not have any idle mixture adjustment. I am also currently suffering from my ICV needing a proper clean and as a result my car is idling around 12/12.5 on the AFR gauge. All is good on throttle. When the ICV is properly cleaned I expect the car will idle around 13's as it previously did.
I have noticed a GURU racing chipset on ebay and in the blurb it says that "unlike other aftermarket chipsets your car will not idle rich with our chips" or something like that. Anyway what are the thoughts on Promax vs GURU racing chips? They are currently a bargain and if I thought I could change over chips (and they were decent) and my idle would lean out a bit I would give it a go?
Thanks again in advance
Stuart
Stuart
