Air conditioning - std or auto
- Thread starter paulbox
I have not seen the standard set up but I can tell you the upgraded climate control seems to be a waste of time and money IMO[&o] For example whatever temperature you select and then push AUTO whatever speed the fan kicks in at it never seems to adjust! 10/10 times I find my self manually turning the fan down so I can't fathom what exactly the auto climate control is meant to be doing, unless of course its the operators fault[ORIGINAL: paulbox
Please can anyone tell me the difference between the air conditioning fitted as standard and the automatic version I would need to pay extra for.
Paul
HarryBox4899
Metallic ~ Lapis Blue
Auto Climate
Park Sensors ~ mainly for parking in my tight garage and the missus insisted, although shes propably better at parking that me!
Wind Deflector
Whats your opinions, i'm really beginning to regret not going for the 19" wheels as they look smart. Anyhow the above options took me over my already stretched budget - but did i spend wisely?
Thanks, Harry
Paul
ORIGINAL: paulbox
My only dilema is whether to have auto aircon as recommended by the dealer or manage with the standard (which used to be an option) system. I know it will only save a few hundred pounds but like Harry my budget is already fully stretched.
Paul
I wouldn't worry about auto air con if your budget is stetched live without it as living with it doesn't seem to make a heap of difference compared to the standard kit IMO [&o]
But to be honest, I very rarely use it except for a quick demist....it's just too noisy running at max for as long as it does.
ORIGINAL: Rodney Naghar
HarryBox4899
Harry
I settled on the following spec:-
Midnight Blue
Blue Roof
Stone Grey Leather
Heated Seats
Wind Deflector
Sports Package
Sound Package Plus
Wheel Centres
18" Boxster S Alloys
Std Air Con!!!
Can't wait -The Dr!.
Having said that....do you get the digital display with the regular A/C or the manual controls? If it means paying a coupe of hundred for the nice digi control I'd do that on aesthetic grounds alone [8|]
garyw
Moderator
Over a journey through France the temperature remained at the preset and I didn't have to alter it, from high passes at 17 degrees down to lowlands at 24degree it remained the same.
It does the same on a north -south drive, but on local shortish trips it never gets to operate correctly. i.e. Fans going flat out and Yes I turn the speed down..[&:]
As your looking at an open top, I would consider how often you have the roof down, as obviously it wil never be able to maintain constant temperatures with the roof down.
I would have AC without a doubt on an open top, just for the demisting capabilities, let alone a cold breeze in your face on a hot day and the roof down [
garyw
garyw
Moderator
Didn't think you were supposed to use a/c with the top down (or windows down for that matter).[:-]
Your possibly not supposed too [
Waste of energy I agree, which is possibly why I didn't get a xmas card from Greenpeace[
A situation where the "auto" is a waste of time, which is why we use manual and send the airflow to where we want it.
To add, another thing Auto does is send the air in the direction it needs to to maintain the temperature required..
garyw
ORIGINAL: garyw
garyw
[8D]As I like the top down most dry days whether/ weather[
With regard to freebies, keep pushing the salesman - an ideal situation is where you are able to make enquiries at 2 different OPC's, and it's just a question of which salesman 'sweetens' the deal the most.
I found that when I mentioned that the Merc garage would offer a few extras FOC on an SLKAMG, I mananged to wrangle coloured wheel crests, mats and a dealer fit 6CD (worth about £350-£400 total) for my 987S.
I did it with my previous 986S too - I got him to agree to a Tequipment boot net plus wheel crests & mats. When he saw how much the boot net (complete with stiffened contoured base to fit the entire rear boot!) actually cost (about £200!), he did go a bit pale, but he honoured the agreement.
Just be firm, remind them of an alternative and give them an incentive like, 'c'mon, to seal the £40k deal you can give these few bits and bobs, surely?'.£400 is only 1% of £40k!
Works every time for me - I never buy a car without some concession from the garage! Remember he wants your cash for his commission - popping toward the end of the month can yield results, as if his sales are down for that month, your purchase will earn him commission to appear on that months pay cheque.
Good Luck!
Rob[
PS - Always get them to write down any agreed 'extras' on the official spec sheet with 'Free of Charge' in the cost column - no way out then![
Paul
HarryBox4899
Cheers, Harry
Yes, dealing with OPC's is a bit different than BMW centres it has to be said, and they are normally pretty tight - I think the 'private' route to seel your Beemer might be the most efficient. How about getting a PX quote from your local BM garage and then waving that under the OPC's nose? Good luck, and welcome to the Boxster experience - fantastic car!![
Paulbox- IMHO the auto-climate isn't worth the extra over the standard feature aircon, so I would agree with you on that. The 6-CD stack is well worth it (if you like music) and it all fits neatly under a plastic panel at the top of the front boot. Very easy to get to, doesn't intrude into boot space and very discreet.
Hope this helps with your decision.
Rob
HarryBox4899
Harry
Dapster
![1595F96ECC024DA4883D0816D24E04AC.jpg](https://www.porscheclubgb.com/forum/legacymedia/upfiles/1249/1595F96ECC024DA4883D0816D24E04AC.jpg)
