devans
Hi Richard, cleaned all connectors. Had to drill a hole in the tilt sensor box to drain out loads of water. Do you know if changing the battery back up is possible and finally, can the tilt sensor box be opened up in any wY to get at the inside for a deep clean. I'm coming up against a brick wall here with this one. Alternatively there are some second hand upgrades available but these require new brackets and connection wire. Thanks
